'88" 15HP Evinrude Waterpump???
aalleexx
Hi -<br />new to this forum....Love it!! I just bought a '88" 15HP Evinrude.Changed the Carb kit and now she runs good, but when I put a hose with that thing on the bottom to see if the water pump is flushing water, only a little water comes out. I am guessing that if I put her in the water a lot more water will come out. Do you think that if I run it like this for one hour I will ruin the motor?<br />please help
OBJ
Re: '88" 15HP Evinrude Waterpump???
Welcome to iboats Alex!<br /><br />Are you talking about the "pee" hole under the lower engine pan? Try sticking a wire up there. Might be plugged up. And better yet....if ya' don't know when the impeller was changed out the last time, get to your local Johnny/Rude dealer and get a pump kit. 'Bout $35. You get a new pump housing, impeller and all the stuff needed to give you an up to date pump and piece of mind. And they ain't hard to install.<br /><br />Keep us posted if you have any questions.....thanks.
aalleexx
yup, you were right, took her out for the first time today she worked really good, the little whole was clogged, got a wire and unclogged it, now it's perfect...the only thing tho...I have the engine on a 14' jon boat and I thought it was going to be a lot faster..since the engine is a 15....but it's not bad..<br /><br />thanks
