greatwhite
- Feb 14, 2003
- 6
Suzuki 1987 DT150 (dual plug per cyl) <br />Port side coils will not fire (coils ok) at idle but will fire at mid to hig rpm. (Checked with tester). When in gear only able to get to higher rpm by raising motor out of the water to get the revs up. Will only fire (port side) at 1/2 - full throttle and quits running below that. No backfire, just stops firing on port side.<br /> *Oil inject was removed long ago, recently low oil reset unit fried and was removed. Could this be the prob and or can it run fine without it? <br />Thanks
