Move over from old thread:
Re: Opinions on Searay Seville 1987
Originally Posted by joejacobi
It currently stalls going into forward, reverse and neutral - just doesn't seem to want to idle at all?
"Newbie here - obviously an old thread - however, no need to start an new one - I just bought the same bought - 87 Seville - in overall good condition, minor cosmetic items to be taken care of - runs really well, although stalls the odd time idling really low going into reverse - old tank of gas, possibly water in fuel - going to get some additive tomorrow and run it through - first day with boat! I'll post some pics soon...
You really should start your own thread instead of reviving these old ones. Your problem could be the lower shift cable being bad, if it is replace it, do not waste your time trying to lube/free it up, you can't, I know cause I had an 87 Seville, had to put three of those in over the 17 years I ran it. If you pull the engine cover and watch the interrupt switch on the engine when you shift I would bet it moves to kill the engine and does not return, that is due to the lower cable."
