Fishnfeever
- Sep 18, 2007
- 6
I've got an 87 Mercury 150V6 XR2. My symptoms are 2 Cylinders (#'s1&6) getting spark but, when I pull the plug wires, those two cylinders don't seem to make a difference when Idling. It idles pretty shaky and seems like all pistons want to kick intermittently. Worse with load. Also hesitant/slow out of the hole. Have set timing & Carb floats and checked carbs according to Secol manual. Stator Ohms good I think, Switched coil packs with known good ones and no difference. Switched plug wires around, no diff. Switched leads on Switch boxes, no difference. Compression is 121 on all cylinders. I don't live above 2500 sea level so jets are ok i think. Got flywheel off for visual and Magnets look ok. Not very experienced but on my way and my father has made a living as mechanic so I can fix if I can narrow problem. Want to be sure of problem before buying whole new or any part of expensive Ignition system. Would I be wasting my money buying a trigger? Please advise....anybody!
