Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
hi guys I’m not getting continuity from the grey wire on motor terminal strip to signal wire at tach. My question is can I run a new wire from motor direct to tach?
Did you isolate the wire (unhook each end) before testing? If so and the wire is broke yes, you cane run a new wire. I suggest a bullet connector near the harness connector in case you need to pop the motor off for some reason.
