87 Johnson 70 Telltale sputters
cemiii
It seems to me my impeller is fairly new but the water stream now spurts intermittently. Is this more likely an impeller issue or would the motor missing cause this?
chris
jtexas
Re: 87 Johnson 70 Telltale sputters
test your overtemp horn - find the temp switch at the end of a tan wire high on the cylinder head. peel back the rubber sleeve and touch the bare wire to the head, keyswitch "on", a steady tone should sound.
stick a wire or something up in the telltale hose to see if any insects have nested up in there.
A misfire wouldn't have any effect on telltale stream. But an overheating engine might misfire.
A nearly new impeller can be damaged by dry running, or running in sandy water. a gasket or grommet could be letting water escape. etc. etc.
