Ok second post on this motor. When i got this boat it was running really bad and surging/boggin down at all speeds above idle. All cyls above 100 compression and all within a few psi of each other. List of new parts;
spark plugs, spark plug wires, power pack, one coil replaced, rectifer replaced. carbs cleaned out. fuel bulb replaced.
Seems like every time I worked on it, it would run better. Now its runs really well on the muffs idles good and very responsive when u snap the throttle, but seems to idle a little rough on the water, at up to 3/4 throttle it runs pretty good. Once you get past half idle u can see/feel the surge and at full throttle will run briefly and bog down.
This boat defintely had an ignition problem with a spark tester attached u could see the spark was intermittant and now im kinda stumped. Im thinking maybe the carbs still, but when u squeeze the primer bulb at surge it doesnt do anything for it.
heres the video i took a couple hours ago
70hp johnson - YouTube
