No spark on the port side of engine. My engine has 2 power packs, I have swapped them and the problem remains on the port side. I even swapped a coil just to be sure that all three coils aren't bad. I tried following the Seloc ignition tests and all seem good except the charge coil resistance is low for both sides of the engine. I do not have the "CD Voltmeter Tester" that they refer to in the book. I am getting ready to pull the flywheel. Are there any other suggestions to narrow down which component is bad? Can the Stator be reversed to see if the problem moves to the other side?
