Re: 87 johnson 150 compression low
Rick - I'm guessing this is a rebuild or remanufactured engine? I have a reman. engine (has a large sticker from a remanufacturing company.) The cowl says "175 VRO, it has no transom bracket, and the engine model number translates into an 82 235 HP. My understanding is that in '82, VRO was not even offered?? It does have a VRO fuel pump, but I pre-mix. <br /><br />The same mechanic who I use also did the work on this engine for previous owner and he said that until he figured this out, it was a bear finding parts. Now it's no big deal. My understanding is that the mechanical parts and carb correspond to the '82 235, but the ignition parts, and the VRO fuel pump, are different.<br /><br />Based on my/our experience, you might need to order parts based on what's on the engine rather than what either the transom bracket s/n or engine s/n call for.<br /><br />Good news is that inspite of all of this, the engine runs perfectly nowadays.
