ShoalSurvivor
- Aug 1, 2012
- 256
Many people have warned me about the impeller and seal... so I decided to inspect/repair. I would appreciate any feedback on my findings...
I removed the water pump and will replace the impeller and housing. The inside looked a bit rough:
I think I should replace the gear oil, or at least inspect it. If I replace it, is the hex screw a drain hole, or am I just supposed to use the vent/fill holes? What type of oil? Should I get into the gear housing or leave it alone?
Next, I'm just curious where water is allowed, and where it's not. When I look down through the top by the head, with the lower unit removed, I can see daylight. It also appears that the unit where the shift coupling attaches is exposed to water. But It seems that water should not be in this area:
Is it?
The idle exhaust boot also looks a bit rough and there is wetness in that area:
Should this be replaced? Any suggestions on replacing it?
Next, a few of the bolts on the powerhead are rusted. Everything else looks pretty clean. Should I replace these, or leave them alone?
Lastly, my prop has a few chips on it, but otherwise seems ok. No major dings. Should I sand/paint, or leave it alone?
Thanks for any tips or suggestions!
- Michael
Is it?
- Michael
