87 Force 85 hp-Need Help!!
freakshowtony
My wifes father has a 87 bayliner with a force 85 hp outboard. He bought the boat 2 years ago and just let it sit. It ran when he bought it and now I can't get it to start. I pulled out all the old gas and start with all new. Replaced the carbs and checked for spark. I can't even get this thing to fire on carb clean. Any help on what you think i should look at would be helpful!
Thanks
Tony
roscoe
Re: 87 Force 85 hp-Need Help!!
Don't use carb cleaner or starting fluid in a 2 stroke motor, use premixed gas.
Check the kill switch.
Check for spark.
Check compression.
Advance throttle only, to full.
Squeeze primer bulb.
Actuate the choke.
Turn the key.
mrix
Roscoe's right - carb cleaner and starting fluid is bad for two strokes.
I've always found that a little bit of WD40 will help get some compression back (not to much though), If you have a seringe or some method of spraying it, use a premix of 25:1 (twice as much oil)
if you have spark it sounds like you might have a compression issue.
Good luck,
-Mark
