87 Bayliner OMC out drivve problem
trief
I purchased a 87 capri and intend on restoring it I have a problem with the out drive it seems to have water in it and I done know where to look for the issue. It also does shift not easily into forward or reverse but the prop will not turn.
any help would be appreciated 87 bayliner capri 2.3 165
:confused:
dubs283
Re: 87 Bayliner OMC out drivve problem
should remove the drive, drain the lube and pressure test it
this will pinpoint the leaky seal
also a good time to inspect the bellows, gimbal ring, coupler, u-joints, etc..
shift issue could be worn shift cable, just go with a new one and adjust properly
trief
Re: 87 Bayliner OMC out drive problem
Thanks I will remove it and Drain it. What is the best way to pressure test the unit?
