87 bayliner capri with v8 i/o wont start but pops???
cruizerfj40
So I have the 87 Capri with a v8 and a quadrajet carb. When I turn over the engine it pops real quickly and doesn?t stay running. (By the way this engine ran last week for about a hr. very smoothly) I can see that it has fuel getting to the carb when I throttle it, and it has spark also. If I gas it all the way it will start for about 3 secs running at high rpms but then stop. I know it is not a fuel problem because even if I put starting fluid in the carb it won?t stay running. Any help would be nice so I can use this gem.
Thanks for your time
Don S
Re: 87 bayliner capri with v8 i/o wont start but pops???
If you have good spark, pull the plugs and crank the engine over and see if any water squirts out of any of the cylinders.
Ayuh,.... Welcome Aboard,...... What do the spark plugs look like,..??
Ya say it's gettin' fuel, so, some diagnostics of the ignition is in order.....
wellcraft-classic210
Master Chief Petty Officer
Sounds like it could be some sort of a spark timing issue.
one thought -- Is it dry inside the distibutor cap?
cruizerfj40
the plugs look good little carbon but not bad, and not wet either
and no water came out of any cyl
Don S
Do you have a bright blue spark coming out of the coil that will jump a 1/2" gap when cranking the engine?
cruizerfj40
yeah it has a strong spark out of the coil........sorry i had to go check..
Don S
Is it that same blue spark coming out of each spark plug wire? Bad cap, rotor would kill the spark.
If you do have good spark at the plug wires, try this.
Hook a jumper wire from the POS battery terminal to the + terminal on the coil and see if it starts. If it does, you need to remove the jumper to shut it off.
cruizerfj40
so i have good spark out of all 8 and i tried the + to coil andit didnt start aswell...... any other hints or thing i could look at.......thanks for your time again
Don S
Might think about pulling the carb and check to see if it is full of fuel or water, and how much crap is in the fuel bowl.
cruizerfj40
that was my first thought. so i had the carb rebuilt and drained all the fueland put new fuel in also changed both filters(the one on the carb and by the pump) and it had no build up in either one.
cruizerfj40
And don s. i also live in wa. by olympia if i cant fix this on my own do you know of a good place to bring her that wont stick it to me? thanks
Don S
Have no clue about Olympia area. Where I'm at, there isn't anyone I would let touch my boat.
cruizerfj40
is there any sensors or anything else i could try on this thing?
Don S
What has been done to the engine since the last time it ran normal.
riptorn
Check for chafed or bare wires in or around the distributor. Is the alternator charging?
