87 48hp jonnie cant drop lower unit
crazy charlie
A friend asked me and I dont know.He is replacing the water pump in his 48 jonnie and I assume he has to disconnect the shaft to drop it.He has all the bolts out and wants to know how to get it the rest of the way off.Any help would be appreciated and I will pass it on.Charlie
D
DJ
Guest
Re: 87 48hp jonnie cant drop lower unit
Look for the shift rod attachment under the bottom carburetor.
crazy charlie
Thanks DJ,does anything else have to be disconnected to do this or is it just that attachment for the rod?? Charlie
D
DJ
Guest
Charlie, <br /><br />That should be it. Make sure you get the bolt under the trim fin. The fin above the prop.
crazy charlie
Thanks again,all bolts are out ,thats why I knew there had to be something else.Charlie
