I have a 87 2.3L Ford that keeps shearing the pin for the gear on the distributer. I have replaced the entire distributer assembly and there is no wear on the gear. The latest shearing occurred within 2 hours of running after the distributer was replaced. There is about 400 hours on the engine and I have only owned the boat for the last 100 or so. A friend suggested that I should replace the pin with a hardened pin and change the oil from a straight 30 weight to a multi-viscosity. He thinks it might be creating a challenge for the older oil pump. When the engine is running I have great oil pressure. My guess is that I have a oil pump that is binding at times and causing the pin to shear. This usually occurrs when on plane at approx 3500 to 4000 RPM. Rowing and being towed is getting old. Any and all help would be appreciated. Thanks....
