I recently got a 1986 sea Ray with the Mercruiser 3.0 and from what I see in really good shape for most part. I got new battery, trying to start and it cranks and never starts but it sounds like it's just not getting spark or maybe not allowing spark like a kill switch is engaged or something. I've tested the coul wire and a few distributed wires with spark tester and no spark seems to be the problem. I have put new plugs In it gapped to .035 from motorcraft and both distributed and rotor look brand new so please help, ignition has recently been replaced by previous owner recently and he mentioned the starter having an issue and that might cause it no spark but I thought starter simply just turns the flywheel correct ? I don't think it has anything to do with spark! Any help be appreciated! I also took carb off and cleaned entirely and all fuel lines and filter /pump and got some thick green sludge out of filter elbows and ends of fuel hose...... What else can you think it could be? Is there a kill switch and if so where?? It's 1986 sea Ray Seville
