Use a Tubing Wrench, not a regular combination wrench...
I can see where the tilt/trim pump is but where is the hydraulic fluid res? I was thinking I would refill the res and run the tilt/trim to see if I can identify the leaking component, provided that's what the problem is.
How can I tell if it is a saltwater use package.
One more thing. We just bought the boat and my wife and I had planned on camping on it for our anniversary this month. Can I run the boat with no tilt until I get it fixed or are the rams required for additional support for the outdrive? I am aware that I have to raise the outdrive before pulling the boat out of the water.
What I don't know is the hose full of water and if it is do I have to do anything special when I put it back together, like fill it with water to prime it or anything?
