86 merc thunderbolt IV problem
hemiman74
I need to know where to get a ignition module for 86 mercruiser 350. i was idleing went to nuetral and boat died and would not start again. It turns over but no sign of ignition. I replaced the coil and nothing so took it back to the store. I removed the pick-up coil and had a guy check for spark and got spark. So coil is good pick-up good it wont turn over while in gear and will while in nuetral. Im thinking the breakerless ignition module thunderbolt IV. Please help me out guys!! Thanks
rndn
Re: 86 merc thunderbolt IV problem
You should post this question in the motor forum, not the Baja forum.
rndn
I know, but this is more of an owners forum and the engine experts keep an eye on the engine forums. Your question has been posted since July 20th and the only response you got was from me telling you to post the question in the engine forum. Your issue is not from Baja it is from Mercury. If you had a question about your boat related to the hull, place the question here.
