Re: 86 Merc 75 top speed
Thanks again JM. Okay, I'll look tonight or tomorrow and find the numbers on the current prop. And I'm making a run to West Marine (everyone's favorite weekend thing when not in the boat...right??) and will look at a RPM guage. Found bunches on E-bay, missed a couple already, so we'll see. My run after I patched the bottom (it was a hairline crack...I only noticed it because water was dripping out of it after I rescued the boat from my brother) was great. When I got the boat home and pulled the bottom plug, I only got a little dribble for a couple of minutes. So it's definitely not taking on water, at least in any amount worth worrying about. Keep in mind also that the boat is 38 years old. Heck, for it to not leak anymore than it does is pretty good as far as I'm concerned. So, I will get the numbers (the easy part), and get the tach (easy, but not as).
I also talked to the mech that got the motor running right for me, and he said pretty much the same thing, but even without a tach, the prop could be just all wrong, depending on what I find for the numbers. I have also found an old board (
www.outboard-motors.us) with a bunch of really good Mercury (and other motors) info on it. Found a sheet for determing the proper prop based on some generic numbers (boat length, weight, motor size, use (number of people carried), etc.). Also lots of good info on the posts that has helped increase my knowlege base tremendously. Only problem is most of the posts are at least 4 - 5 years old. Looks like the board is not used anymore, but still there.
So armed with all this good stuff, I feel ready to tackle all this with a great deal more confidence, and feel I will end up getting my speed and performance up on this motor. I'll certainly keep in touch here and let you know what I find.
Thanks for the responses, and see ya on the water!
