i have a 86 johnson 25 hp , its only done 12 hrs since new.
it had a new impellor replaced 12 months ago, (sitting around) and it pumps water out the telltale very nicley.
problem is when i get underway, all of a sudden it will stop pumping water out the telltale, and start to get hot. after paddeling back to shore, i can restart the motor and it will work again. seems to be only under load in gear, that it stops. then i take it out again, and after about two minutes it stops again and starts to get hot again. ~FRUSTRATED!~ HELP??
does this motor have a thermostat?>
