86 Johnson 90 Port Cyl's not firing
kdoherty
1986 Johnson 90 horse. 2 port cylinders not firing. No spark at either end of wires. Recent hole (since repaired) in water hose sprayed salt water in area. Ideas?
JB
Re: 86 Johnson 90 Port Cyl's not firing
Howdy, KDoherty.<br /><br />OMC V4s used seperate electronic ignition systems for the two banks of cylinders.<br /><br />You have almost certainly lost a powerpack. If you switch them and the trouble goes to the starboard bank, you will have verification.<br /><br />Good luck. :)
