Janniklindskov
- Sep 13, 2009
- 44
Hello there
I have just changed the impeller on my Johnson 90 hp. I bought the BRP kit with everything in it. I changed all the parts and put it back together like it was discribed in the manual that came with the kit, and i also looked in my factory manual.
Got it back together and fired the engine up, then it diden't seem to pump proberly. I then took everything apart again and put i back together. Fired her up again and then it was a little better.
Here are some videos of the engine running after the second time i got everything together....
http://youtu.be/Djm-W6NJbIs
http://youtu.be/FgZEoyTo2rs
Hope that you can see on the videos that it is like i dosen't have a steady pee....
I felt one side of the cylinders and it got more hot than the other, so hot i could't hold my hand on it. The other one i could hold my hand on.
Now my question is, why is it not pumping in a steady stream or is this stream enough?
After i had the engine on idle for a couple of minuts the rectifier suddenly caught fire
I got the rectifier of the engine and i could see that there is a large space underneath it.
Is the impeller not pumping enough water so the rectifier gets to hot? It shoud be noted that the voltmeter in the boat has been showing alot og voltage going to the battery so maybe the rectifier has been bad for some time?
Got a picture of the rectifier after the fire...
Hope some of you can help me with my problems, because the boting season is comming soon
Jannik
Jannik
