Hi,
Following the basic troubleshooting procedure in this thread -
http://forums.iboats.com/showthread.php?t=158071
I've arrived at this part:
"2. Electric and manual start: Flywheel rotates but engine does not attempt to start. .
Remove a spark plug, reconnect it and hold it against engine block. Keep it there while turning engine over.
Does it make a hot, blue spark when attempting to start?
If no, troubleshoot ignition system."
This is after the boat was parked for the winter (it hasn't run this year).
Is there a post or sticky somewhere that spells out the ignition system troubleshooting. What are that things I should be looking for?
Thanks
Thanks
