hi again. i have an 86 johnson 25 hp. done 15 hrs work in its whole life.
went out today. ran great, for about 30 minutes. stopped, fished, then went to restart, and motor wouldnt start and run properly, and i was getting a major compression lock, sometimes when i pulled the starter.
and wouldnt stay running.
had to get towed back in by the coast guard. bugger.
sometimes it will run, but i seem to be getting the compression lock sometimes when i try to pull start it.
could it be firing too early somehow? it seems to run ok, then gives a big cough then stops. i have checked the cylinders, no sign of water in them. electrical problem? i am ready to drop this motor in the ocean as an artificial reef. would the cdi unit play up and cause it to spark early sporaticly?
not game enough to take it out any more. any ideas ? thanks.
ps.. now it wont start at all. :-(
