Peter Buschlen
Thread starter- Joined
- Jun 7, 2001
- 1
When I lay down on the throttle wide open the enging "Bogs Down" and Hesitates. If I pull back slightly the engine will rev fine (4500-5000 RPM.) I need the extra kick for Water Skiing. This problem developed rapidly (one afternooon), and was not this way 2 mos ago. I rebuilt both Carbs, changed plugs, new fuel diaphram, checked fuel/Air mixture. Both Butterfly Valves open horizontal at full Throttle (engine off though) Compression on all cylinders OK. I'm starting to think Ignition? This engine has the black coils not the blue ones. There seems to be a little play in the linkage (Butterfly Valve) on the top Carb. Is this normal? <br />I hate to blindly throw money at my undiganosed problem. Please Help.
