Re: 86 dt 115 little reverse problem
I was new to boating a year ago,I'm an auto tech 30 years . If you are going to work on your motor, get the suzuki manual. it explained everything I need to disassemble a back up motor, I misplaced the manual and tried for about an hour to firgue out how to get power head off. found the manual, had it in pieces in about 45 minutes.If you are going to do your own repairs GET THE MANUAL,then if you still have trouble you be able to follow along when someone is tring to help. good luck
