86,70hp evinrude carb problem
newboatman1962
just bought a 1986 ,70 hp evinrude ,it starts and idles good,but when you try to speed up after a certain point it starts to shut off,unless you pull back on the throttle,you can also push on the choke button 5 or so times and then it will let you speed up and runs fine,untill you slow down again,,what could that be??
Joe Reeves
Re: 86,70hp evinrude carb problem
After you push the key in (engages the fuel primer solenoid), does the engine hit full throttle and stay there OR does it simply speed up a little?
Sounds like fouled carburetors.
Joe Reeves
If the "speeds up a little" is temporarily and the rpms dies down again...clean the carburetors.
