'86 225 wiring harness plug...help !
22ISLANDER
After some long trial and error, I got the beast running a few weeks ago. It seems to run great, so I've spent the last couple of weekends changing bilge pumps and thru-hulls.
A friend came over to have a peek at things, and I had the engine cover off and was too lazy to climb up into the boat to start it up, so I unplugged the big red connector on the engine and jumped it with a screwdriver.
One of the female terminals from the plug pulled right out of the red plug !!!
Even after pushing it back in, the engine will not run with the key ( I know I have a broken wire inside the plug now).
I'm in need of the wiring diagram for the plug so I can bypass the plug with another wire, and hopefully launch today.
I really dont want to tear all the wires out of the plug, the only way to do that is to destroy the plug.
Anybody have a diagram? I cant find one in my manual.
E225TXCUB
AnglersEdgeNY
Re: '86 225 wiring harness plug...help !
Islander,
I have a wiring diagram for my 86 Johnson 225. do you know if they
are the same?
If so I'll scan it.
22ISLANDER
Thanks Angler, they are the same.
I just need the wire placement in the plug. The darn thing is not made to come apart
AnglersEdgeNY
Islander
Here's the scan of the harness. If you need other wiring info let me know
Mike
