I have a 76-77 85hp Merc.Electronic Ig. I lost #4 piston & rings & lower bearing. I had #4 bored 30 and replaced upper & lower bearings. Reeds all look good & gaps were all correct. Boat rain at 35mph + before.(Tach.not working) Motor started in tank & ran good.Took it out to put breakin time on it,(I'm running 25/1 oil for breakin) Motor seemed very weak! Didn't push it but tried to run speed up & it would barely reach 20mph very weak! I thought it might be spark advance and carb linkage needed to be adj. Took it to a Boat Mech. to set this all. Went back to talk to him today & he said when he set everything, it wouldn't run at all. I had a leak in gasket at bottom of 4 inch spacer under powerhead. Took it home & fixed this. Can anyone think of anything I missed? The Mech.said to bring it back after I fixed gasget,and he would try again. Thank You all Chuck
