85hp Merc runs with muffs / dies in water/gear
jayhawk5
have a 77 merc which runs great with muffs / shift into gear and will rev up out of water. Put in the water - starts and idles great, dies after shifting into gear.
Have done carb kits / cleaned carbs good. Gas is new, with a new gas line.
Any thoughts / help out there?
KC5
fishinhardwater
Re: 85hp Merc runs with muffs / dies in water/gear
ever try leaving it on the trailer and starting it up and giving it throttle in gear??
jayhawk5
yes, have left on trailor, also now have in driveway in stock tank, does same as in lake. been reading other similar problems and sounds like I need to adjust idle / fuel mix to possibly resolve.
compression test good, and also all wiring has been replaced. this is a time consuming / costly for a novice...
fishinhardwater
yea the carbs need adjusting... its not getting enough fuel or air or something when its under a load, but runs fine when the props spinining with no resistance.. try adjusting the screws on the carbs while someone else drives your boat.
Chris1956
KC5 - The idle mixture is not correct. Those motors need a rich mixture or they cannot accelerate. If the motor runs smoothly at this point, try richening the idle mixture by opening the top carb 1/8 turn. If it doesn't accelerate smoothly, open the bottom carb 1/8 turn and try again. Repeat the sequence if necessary. You are done when you can make the idle mixture rich enough to accelerate smoothly, and still have decent idle.
