Last fall picked up a 1988 85hp force in good condition. It appeared that the prior owner replaced the lower unit with an older Chrysler (white).
When I started it this weekend it ran hot. Dropped the lower unit. Impellar looks like new.
My question I did notice that the water pump assembly connects to the brass water tube without any type of rubber gasket. Cannot tell from the waterpump thread if a gasket rubber sleeve is supposed to be there. If I need one where do I get it.
If the water tube is a friction fit what else could cause the motor to run hot. Motor sat for probably seven years before I got it. Could it be theromastat. Ran hose through system does not appear to have any blockage.
Thanks Tom
Thanks Tom
