O.T.Water
- Sep 12, 2009
- 88
Hi All, Had to replace one of the plastic ends on my timing adjustment, it had split. So I did both ends and am working through the link & sync in Clymers and got to Crank Timing. I've pulled the plugs and grounded the wires, jumped the neutral switchand moved the throttle to WOT. Hooked up two different timing lights and can't get either one to flash. I've been through the setups over and over and no luck. Any suggestions as to where I may be going wrong? Thanks O.T.
