Re: 85hp Chrysler Power Pack is good, now what?
1978, Magnapower Ingition, white box on side of engine with coil attached. Two wires on distributor one black/white and one blue. I think I got it going, started and ran strong, found the battery ground wire on the breaker panel was loose. Not sure if that would cause it to crank but not run. Heres a question though.
Before the problem I was having was no spark most times, sometimes it had spark and would start at which time the tach would go crazy shooting straight to 6000rpms and staying there even at idle. I tested the power pack and coil and found that one of them was bad, but I didn't know which one, so I replaced them both. Now the tach is operating normally and the engine seems to be running great since I rechecked all the grounds. But I still don't know if the coil or the power pack is bad. I'd like to know so I'll know which of the old parts I took off is still good. Any ideas?
