Hey guys, been reading around on here past few day, good stuff. Recently I bought a 16 foot Stratos boat with a 1978 85 HP Johnson outboard for a good deal (First boat so bare with me). I have rebuilt the carb, changed the impeller and had the lower unit resealed, and been doing some other stuff cause none of the gauges were hooked up. Got all the gauges powered up and the tach gauge working. The one gauge I really would like to work is the water pressure gauge. I t'ed into the pee line and its a 30 psi gauge. It only registers like 1 psi, if i plug the pee line with my finger it goes up to 5ish psi at idle... here are my questions:
1.) can i just plug the pee line so I can just rely on my gauge?
2.) trim gauge... it has power... I found the sender unit for in in the left side of the trim assembly with 2 wires coming from it. Do I ground one of the wires and the other wire go to signal place on trim gauge?
3.)I noticed the spark plugs in it were QL78YC and my motor calls for L77JC4 or QL77JC4. How would this affect motor operation and should I change them?
Thank you so much in advanced!
Robert
Robert
