Re: 85 Merc 115 Power tilt/trim beeld procedure
Hello and welcome to Iboats.
First off, are you sure of the year?? from 84 on the power trim/tilt was a single unit without hoses. It was mounted on the outside of the boat integrated with the transom mount. like in the picture.
To bleed the first generation system, you simply fill the pump, cycle all the way up and down a few times and fill to the top again, it's a self bleeding system.
Hope This Helps.
Craig
