85 Mariner-fast idle causes gears to grind putting in gear
Jeff Leek
2 cylinder with idle set as low as it will go and is running fine except when putting in gear (especially when putting in reverse) --clunks and grinds real bad. Do you have any suggestions on a fix for this problem. I hate to let it tear out the lower unit.<br /><br />Thanks,<br />Jeff L
heybaylor
Re: 85 Mariner-fast idle causes gears to grind putting in gear
what rpm is "as low as it will go "??<br />also when you put in gear , do not "ease it into gear , just with a quick movement, do it
Jeff Leek
I dont have a tach. I am guessing the rpm's are about 1200. I do use the quick movement, but it still grinds and clunks. I have other outboards that do not do this.
heybaylor
most merc,s are set to 550-650 in gear ..<br />usually results to about 750-900 in neutral..thats IN the water..<br />check your linkage ..you need to get the rpm down if it is really 1200 ..it will grind ..<br />there is no syncros in the lower unit ..just a 'engagement dog " ..
Jeff Leek
Was going to fish today, started it in the driveway and the rpm's seemed worse. Gonna have to get it fixed before I use it. I'm sure it will tear something up. The linkage and adjustment is set as slow as it will go. If I push down on the carburator linkage it will slow down, but won't stay there. Almost seems like the butterflies are not closing enough.
