crazyfish180
- Aug 7, 2005
- 5
I recently purchased an 1985 185hp Johnson. The motor was rebuilt in 2002(not sure of how or who rebuilt it) First trip out motor started and idled great. Coughed and spit out of the hole but ran great mid and top end (5600rpm)15in prop. <br />Tried to de-carb to help the poor accelration, did not help one bit. After changing plugs and cleaning carbs did nothing I decided to do a compression check before I took it to a mechanic.<br />Compression on six cylinders between 69lbs-71lbs.<br /><br />Also noticed a water leak under the base close to stering arm (could be base gasket) understand no relation to compression issue...<br /><br />Pulled the heads, cylinder walls look excellent, still have honing criss cross marks. Pistons look great. Head and gaskets show no sign of leaks. <br />Did notice play in pistons, not sure what the tolerance should be but seem to more than a 2 stroke should be.<br /><br />Before I dump $2500 into a rebuilt powerhead...<br /><br />Any ideas would be greatly appreciated.<br /><br />Thanks again for the site.<br /><br /><br />Any ideas. Could it be just rings?
