wineyarders
- Jun 22, 2011
- 46
Hi,
I'm relatively new to the site but have done a lot of reading. I've seen plenty of discussion regarding compression but still have a couple unanswered questions. Hopefully someone has a little time to help me on my way.
Short story: low compression on one cyl; I think because it's lightly scored (see pics). What should I do? New gasket, new rings, rebore + new pistons, other?
I guess I'm too new to post photos. Here's a quick link to the photos that show what I'm talking about: http://www1.snapfish.com/snapfish/t...otsc=SHR/otsi=SALBlink/COBRAND_NAME=snapfish/
Long story: I have an '85 Johnson 15hp that I used probably once a week this summer in the ocean. It always needs a squirt of fuel in the carb to get things going, and after that it runs ok, although it will not idle for more than a minute or so at best, and if the engine is off for more than 5-10 minutes I'll need to shoot more fuel into the carb to get things going. Picked up a compression tester and the top cyl was about 70-75 and the bottom was 55-60. The lower plug has a little carbon/oil buildup while the upper was without but had a little chalky residue buildup. Anyway, hoping it's just a bad gasket I pulled the head. The gasket looks pretty good (pic 1) but there's a distinct scoring in the lower cylinder (pic #2). I can barely feel the scoring with my finger, it feels like very fine scratches. Now I'm trying the figure out my next steps. It seems like my options are to just replace the gasket, replace the rings, or rebore the cylinders and pick up oversize pistons. The last 2 options are a bit daunting as I've never completely opened up any engine, and I would need to pick up a few tools to remove the flywheel and deal with the rings and pistons. Looking at the manual and all of the steps doesn't help. On the other hand, I'm pretty much stuck with this motor and want to be able to rely on it to start when I need it to.
Also, not sure why, but the lower cylinder was very dark and moist with carbon buildup while the upper was very dry with a thin layer of chalky substance built up on the front of the piston (pic 3). I scraped most of it off but you can still see some in the 3rd picture. Anything to be concerned with for the upper cyl?
Any advice much appreciated,
Ryan
Ryan
