I recently purchased a 1985, 85HP suzuki. It will run fine in the yard with the flush adapter attached. When i put the boat in the water, it will not idle even in neutral for more than 2 or 3 min. I believe that i heard the rpm drop yesterday when i lowered the motor. I have been able to get the boat, a 15' monarch, on plane several times and it will run 55-6000 rpms @ 50+ mph. drop the eng speed down and the motor will stall, but restarts fine. <br /> I have had the carbs removed and cleaned, replaced the fuel lines and bulb, replaced the diaphrams in the pump, adjusted the idle speed even to the point of having it too high, and still the motor will stall when in the water. I have even duplicated the "in water" boat angle and still it will run on dry land. There is also a HUGE power drop when on the way to the wide open position. It will lag and then catch. gas is fresh as is oil and i have opened the tank and inspected the interior with no abnormalities. Any ideas...Please help....ty
