85 hp ran fine on muff changed plugs now over heating
Simple_Man
ran fine on muffs for preseason start took to lake for cruise ran good. checked my plugs decided to change them, they just didn't look right. Now it over heats on the muffs could this be because the plugs are running better. oh yeah is runs better with the new plugs
Jiggz
When running on muffs, was there water coming out of the exhaust snout? If not, then you need to make sure the muffs and garden hose are connected and placed properly. If muffs and water connections are correct, then it is time to check the impeller. How long does it take before the overheat buzzer activates? If it's less than a minute, there's obviously no cooling water going through the head. What year is your 85HP?
Simple_Man
Opps it is an 87. it took about 3min to sound the buzzer just ordered an impeller kit and thermostat. the muffs are in the same place as they were the day it ran on them directly over the intake.
Jiggz
So is there water coming out of the exhaust snout when running on muffs? If so, does the water tend to increase in volume when you rev it up a bit? If not the impeller needs to be replaced.
gm280
Yes sounds like its time for a impellor replacement. But also make sure all the water passages are clean and free as well when you have it down to change the impellor. JMHO!
Simple_Man
yes the amount of water increased when i reved it. planing on changing it tomorrow and the t-stat when it gets here also going to add a tell tale to it. what size should I make the tell tale? is 1/8 in too big. oh one more ???? i couldnt get TGK plugs are autolite ok?
jerryjerry05
The Autolite are ok.
Are they the surface gap plug?
The whizzer. I install a small diameter.
1/8th is good. anything will work.
Simple_Man
Thanks guys changed the water pump "easier than the sticky made it sound" t-stat is done. heading for the lake now to test. will let you know
Simple_Man
THANKS all the Admiral and I just got home form the lake Ran great
