Hi,<br /><br />I am reposting this and answering all the question that you asked! <br /><br />I have a Johnson 69 85Hp that slips out of gear, into neutral (an stays in neutral) under load. <br /><br />Recently I replaced the lower gearcase complete with a second hand and it had some leaks. I have fixed all the leaks and changed the oil several times.<br /><br />The reverse and Neutral work fine, it just slips into Neutral at around 4K rpm<br /><br />The Gearbox is Hydro-electric <br /><br />I have tried disconnecting the wires to the solenoids and it did exacltly the same thing, ie starting in forward but<br />slipping out under load.<br /><br />I am using "OMC Premium Blend Gearcase oil" but it looked a dirty-greenish colour (not milky) when I drained it<br />last. (after maybe 10 hours use).<br /><br />Could this problem be a blocked/dirty oil filter? <br /> <br />Cheers,
