jbwillis76
- Feb 20, 2009
- 36
Hello all,
I got this motor going earlier this spring with y'alls help and now I need it again. 1986 US Marine / Force
Motor has ran great all summer. 5500rpm and running perfect. Last week I was pulling the tube, parked it and when I got back to it (hour) it was hard to crank and to keep running. I lost 1500-2000rpm WOT and it won't idle. Figured I lost a cylinder and I guess I was right.
Just got around to tinkering with it and sure enough the bottom cylinder (no.3) plug is spotless. Here's what I've figured out so far:
Plug has GREAT spark, same as the other two cylinders.
Compression is 135, same as the other two cylinders.
The plug was wet so I'm assuming it is getting fuel. Took the carb off and cleaned it just in case. It was clean and did not change anything.
I'm out of ideas. Air, fuel and spark and it should run. With the motor idling (best it can on two cylinders) pulling the bottom plug wire doesn't change anything so it is definitely not firing on that cylinder. It is also smoking white smoke VERY heavily right now, maybe because it isn't running right, IDK, but it isn't normal.
ANY HELP!
Thanks as usual. James
ANY HELP!
