Re: 85 hp Force Tilt and Trim Question
I'm a complete land lubber so take this for what it's worth. I've been researching tilt and trim issues and I've read that you may have two relays that control your tilt / trim: one for up and one for down. When you mention a "clicking" sound, that leads me to believe it is relay related. My older boat doesn't have such a thing (I don't think) so I can't really tell you where to find the relays. I've read that they may be inside the engine cover close to where the wiring goes into the engine cover. If you can locate the two relays, swap them and see if your tilt / trim issue reverses itself (goes down but not up). If so, then replace the bad relay. Or better yet, replace both relays and keep the "good" used relay as a spare.
Again, I'm a newbie / land lubber / rookie / JAFE / etc. so take what you can use and flush the rest.
Good luck!
