ATAPIA2002
- May 17, 2009
- 20
Hello all
i just picked up a tilt assembly since my boat didnt come with one i am mechanically inclined but dont know much ABOUT BOATS THE UNIT IS NOW INSTALLED ALL I NEED TO DDO IS WIRE IT WITH THREE WIRES WHICH I ASSUME ARE POWER TO THE SWITCH AND GROUND ALSO THE OIL WAS EMPTY UPON RECEIPT OF THE UNIT, MY ? IS IS THERE ANY SPECIAL WIRING OR RELAYS ,FUSES ETC... THAT SHOULD BE INSTALLED WITH IT OR CAN I GO DIRECT FROM THE BATTERY ALSO HOW DO I FILL IT WITH OIL AND WHAT TYPE OF OIL IS THERE A SPOT WHERE I HAVE TO BLEED IT FROM THE UNIT CAME OFF OF A FORCE ENGINE AS WELL ANY AND ALL ADVICE WOULD BE GREATLY APPRECIATED IF ANY ONE HAS A DIAGRAM, SCEMATIC THAT THEY CAN SEND IT WOULD GRETALY BE APPRECIATED THANK U ALL IN ADVANCE..
P.S. I HAVE AN OUT BARD FORCE 85HP MOTOR
