85 Force
kfruge
I just purchaced the motor on a spectrum center console boat, I am used to other motors. where does the water pump out from the "water pump" impeller, i was used to seeing it " PEE" out the side. But this one doesn't, another question. Do i need to run the carbs dry after each trip? the fuel hose is directly connected , well it runs into the motor shell "callon". Thx
jerryjerry05
Re: 85 Force
No pee on the Force/Chrysler.It has 2 holes out the back it will show there.And the exhaust snout under water.
NEVER run the carbs dry.It can lead to cylinder scoring and failure.J
kfruge
Re: 85 Force
Thanks Jerry, I am use to the other brands and didn't want to burn it up. Thanks for your advise. Also how do you know when to change the impeller?
mauiboy
Re: 85 Force
You can make it pee to the side, I did mine because I want to see by just turning my head it give me a pice of mind check out the sticky on this web.
