timmydoodle
- Jun 5, 2012
- 33
ok guys i have the motor running great so now i drained the oil out of the bottom pulled the vent screw and the fill screw like it says. not much came out so im going to go get oil for it. or should i say lube. Now i looked at the prop and no marks and i tried to move it up and down everthing ok there till i tryed moving it in and out ........Is it supposed to have like 3/8 play in and out???? and thats only where the or to the nut and washer that holds it on. In other words when you push or bump it in the clearence between the nut and washer that holds the prop on and the housing of the prop is about 3/8????????? IS THIS RIGHT????
