giterdone72
- Jan 26, 2010
- 51
After checking my ign electrical as to why my 50hp Force wouldn't idle good, I tested the fuel pressure. Primed good, but no flow when cranking. i pulled the fuel pump cover and saw the diaphragm was torn! I am ordering new parts and I was wondering if when changing the diaphragm, it is necessary to change the 1 way valves in the cover? They look good and the one i can check works good. 1 is screw set in, but the others appear pressed in??? there are 3 in the cover. Any help is appreciated-
Steve
Steve
