tommyarmour
- Aug 8, 2010
- 27
I just put a new fuel pump on this motor. And put on a new throttle cable(still slightly too long).
Let me try to explain the problem I am having. I turn the motor off and fish for a little while then I start the motor back up. I push the throttle forward the clutch engages and the engine revs up a little I push foward a little bit more and she starts to die out at this point I usually just pull pack enough to keep it running then try again its still in gear and moving but I cannot give it enough gas to take off. It usually takes me 5-10 full minutes of pushing forward and the engine almost cutting out I immediately back off the throttle to keep it running while still in gear then try again and again and again until it finally catches. When it does it takes right off and blasts on down the river(Columbia River). As long as its warmed up I can let off the throttle until the boat stops and put it in neutral, then I can just push forward and launch a skiier out of the water over and over, but if I turn the motor off and wait 3-5 minutes I will have this same problem. Its very annoying and I assume its a easy fix, my throttle cable is a bit long and the play is too muh but that is just me whining the problem is not in the cable its to do with gas I assume. New gas, Old gas it runs the same. I do have a new fuel pump in it.
Does anyone have any ideas? I would like to fix this problem, really sucks when you want to move to a new fishing spot and it takes 5-10 minutes to get going more than 5 miles per hour.
I will post pictures if anyone needs to see what I am working with.
