Canadian thundercraft
- Jun 26, 2013
- 4
Hello Everyone, Great site and glad to be aboard. I have an 19' 85 Thundercraft that has a 3.8l with a cracked block. I am in the process of removing the engine from the boat. Basically I am at the stage where everything is stripped down and we are ready to pull the motor and would have gotten it out last night if not for darkness. We tried to separate the engine and have it about 1/2" apart but were feeling some resistance. We are thinking its a spline shaft that is tight but didn't want to pry to hard on it last night.
1) Any tricks to getting it apart?
Once it is out we will inspect the cracked area and perhaps try some JB Weld as option 1 if crack is not to bad.
(2)Anyone have input on the success/failure of this method of repair on a 3.8l?
I have been searching for a replacement 3.8l short (or long) block but am not having much success due to its limited production years (80-85 I think) and that availability number is even lower here in Canada I'm sure.
(3) The 3.8l to 4.3l conversion...worth considering or not and why?
Thanks in advance to all that reply.
Regards
Regards
