Re: 84' OMC 1.6 liter sea drive, 20" or 25" transom?
the seadrives were the 25 in shaft,which is a long shaft,you dont have a transom mount engine due to its design,it can be converted by removingthe seadrive bracket assy,and installing a standard bracket assy,but requires removal of powerhead ,its a bit of a job,if your thinking of installing a new type bracket and want to use your engine,rather than change yours,you can buy a mid section and bracket assy from a salvage yard and mount your powerhead and your lowerunit,you will need to cange a few throttle and shift mecanisms as wellas intake
